Replaced Differential Mount and Subframe Bushings and....
So I just got my car back from the shop after having them install the V2 differential mount and prothane subframe bushings and had them do a 4 wheel alignment and the car still clunks when pushing on the accelerator.
Where do I look next? The clunk is better and isn't noticeable when just maintaining a speed, but if I go WOT then it still clunks.
Have you checked the u-joints on your drive shaft? They clunk when worn out. New drive shaft pretty cheap and an easy install if you have a lift.
Meanwhile, do everyone a favor. Sign in, go to User CP menu (upper left), click Edit Signature and add your Z model, year, shifter, turbo or NA, etc. Saves you having to add it to every post. (Guys here go crazy if you don't lock your Q to your specific Z every time you post...They just ignore questions without enough info) Then click Edit Avatar and you can add a little Z pic under your nick. Cool. You are solid here. Thanks.
Rupe
07-03-2012 08:00 PM
Champagne
FS: 300ZX (90-96)
05-04-2011 09:19 AM
bpealer
09-05-2006 08:26 AM
mewfis138
06-11-2005 08:34 PM
