neutral safety switch
Old 06-10-2011, 04:50 PM
87z
87z's Avatar
Need help
Hey guys I got a 87 300zxt something with the clutch inhibitor is messed up. It doesn't start. Usually I can play with the clutch and it will start but it's not doing it this time. Please help asap
87z is offline
Old 06-10-2011, 05:30 PM
Lurker
noboosts130's Avatar
Check the starter relay.
noboosts130 is offline
Old 06-10-2011, 07:17 PM
bypass the clutch switch and see if that fixes it.
hoov100 is offline
Old 06-10-2011, 07:43 PM
87z
87z's Avatar
The starter relay is in the relay box next to fender under the hood on the right side right?
87z is offline
Old 06-10-2011, 07:56 PM
Lurker
Correct
Old 06-10-2011, 08:06 PM
87z
87z's Avatar
It looks to be ok. How much does it cost?
87z is offline
Old 06-10-2011, 09:38 PM
HexaggramJDM's Avatar
it could also be your neutral safety switch. test both of them, test the relay to see if the magnet contacts and lets current through. if it does, check the neutral safety switch, it might be stuck open. and if that doesn work then check the grounds on both =)
HexaggramJDM is offline
Old 06-11-2011, 09:39 AM
87z
87z's Avatar
thanks ill check them and let you guys know how it worked out
87z is offline
Old 06-11-2011, 12:37 PM
87z
87z's Avatar
ok well i went to go start it this morning and it started right up... weird. since the starter relay was 11$ i bought it and will see what happens. im not expecting any change but one can only hope
87z is offline
Old 06-11-2011, 12:45 PM
87z
87z's Avatar
i thought neutral saftey switches were for auto..? i have a 5 sp and having problems starting it. have to play with clutch while key is turned to start. any ideas? where is the neutral safety switch located?
87z is offline
Old 06-11-2011, 05:08 PM
Not sure why you started a new thread when people have already been helping you on your previous thread...
Merged threads.
NismoPick is offline
Old 06-11-2011, 06:10 PM
Lurker
I was reading over the fsm. Check the clutch switch, and the theft warning relay #2. I'm leaning more to the clutch switch.
Old 06-11-2011, 09:01 PM
there is..and
yes... clutch switch, my bad. Noboosts130 got the correct term.
Old 06-12-2011, 08:52 AM
AZ-ZBum's Avatar
There is a neutral safety switch, but I've yet to see any proof it does anything. It's located on the transmission. There are two switches. One is the reverse switch. The other is the neutral switch.
AZ-ZBum is offline
Old 06-13-2011, 06:44 AM
87z
87z's Avatar
Well the relays I got weren't the right ones... No one has the right ones I guess it's something u gotta get from a Nissan dealer? And I was looking on the Internet and seen someone jump the wires from the clutch inhibitor switch (I have a brand new one) to a harness just above it and says it works. Does anyone know if this will work and what wires I need to put together?
87z is offline
Old 06-13-2011, 09:16 AM
AZ-ZBum's Avatar
It'll work just fine. That's all the switch is, an on or off switch.
AZ-ZBum is offline
Old 06-13-2011, 12:46 PM
87z
87z's Avatar
ok what wires need to be jumped ? picture would be nice
87z is offline
Old 06-13-2011, 03:01 PM
Theirs only two wires on the switch, just cram a wire between the posts when you unplug it. (like I told you to do in the third post.)
hoov100 is offline
Old 06-13-2011, 04:39 PM
87z
87z's Avatar
Ok well the clutch switch wasn't the problem. The clutch inhibitor relay isn't the problem. What else could it be?
87z is offline
Old 06-13-2011, 08:55 PM
Try jumping the solenoid and see if the starter works.
hoov100 is offline
Old 06-14-2011, 12:50 PM
87z
87z's Avatar
it seems to be that if it is either hot out or the engine is warm it is harder to get start or just doesnt start at all..
87z is offline
Old 06-14-2011, 02:59 PM
AZ-ZBum's Avatar
Have you had the starter tested?
AZ-ZBum is offline
Old 06-14-2011, 03:29 PM
87z
87z's Avatar
No. I really don't think it's the starter just Bc it's only sometimes and when it does crank it starts right up
87z is offline
Old 06-14-2011, 04:03 PM
AZ-ZBum's Avatar
Doesn't mean ****.
AZ-ZBum is offline
Old 06-14-2011, 04:11 PM
Have you tried what I said? Also an intermittent starter is usually a sign the starter is going. it's three bolts and a screw and 5 minutes to remove it and you don't even have to jack the car up (unless you lowered it)
If you come on here asking for advice and don't take our advice/ignore our advice, then you should really just stop posting about your problem and ignore us completely.
hoov100 is offline
Quick Reply: neutral safety switch
