drivers side headlight ghosting
Old 02-23-2017, 02:39 PM
Numbnuts's Avatar
Ive been having an issue with the drivers side headlight coming on by itself thru the night. Switch is off, fog lamp switch is off. I jiggle the headlight (turn-signal) arm & it goes out. Is this a common problem? Just replace the switch? Ideas?
Numbnuts is offline
Old 02-23-2017, 05:20 PM
Monkies's Avatar
Check out the video in this post. It is most likely your issue. The small contacts in the switch need some attention.
https://www.zdriver.com/forums/300zx...urn-off-41442/
Monkies is offline
Old 02-23-2017, 09:21 PM
Numbnuts's Avatar
Thank you! It acted up again at work & tonight after I parked it. Its definitely the switch. I jiggled the turn signal (headlight) arm & it went off & on from the drivers side only. I threw it up into the high beam location & tried it again but it didn't repeat. Quick fix until I can pull it apart & clean it up. Thanks for the video!
Numbnuts is offline
zkyleax
11-23-2011 03:00 PM
GARYZ240
12-12-2006 09:01 PM
gram
04-06-2004 01:46 PM
BASEBALL248
01-05-2004 01:05 AM
kewlcat
10-26-2001 09:36 AM
Quick Reply: drivers side headlight ghosting
