drivers side headlight ghosting
Ive been having an issue with the drivers side headlight coming on by itself thru the night. Switch is off, fog lamp switch is off. I jiggle the headlight (turn-signal) arm & it goes out. Is this a common problem? Just replace the switch? Ideas?
Check out the video in this post. It is most likely your issue. The small contacts in the switch need some attention.
https://www.zdriver.com/forums/300zx...urn-off-41442/
Thank you! It acted up again at work & tonight after I parked it. Its definitely the switch. I jiggled the turn signal (headlight) arm & it went off & on from the drivers side only. I threw it up into the high beam location & tried it again but it didn't repeat. Quick fix until I can pull it apart & clean it up. Thanks for the video!
BASEBALL248
01-05-2004 01:05 AM
