300ZX (Z31) Clutch sound
Old 09-16-2016, 04:22 PM
Dolton Ackerman's Avatar
So I was test driving a z31 I want to buy but when driving it, when you let go of the clutch you hear a grinding sound. It doesn't happen when you shift or when your press down the clutch, only when the clutch is released. Any suggestions?
Dolton Ackerman is offline
Old 09-17-2016, 01:53 PM
zxguy1986's Avatar
Figure in the cost of clutch replacement with the asking price of that Z31. Some aftermarket medium-duty clutch models are excellent, readily available, not too expensive if I recall. Check them out. Labor requires a lift to install it and bleed it right. If that's all that Z needs, sounds like maybe a good find. But spend as much time driving it as the seller will allow. It will tell you what else it needs or wants before you settle on a price.
zxguy1986 is offline
Old 09-17-2016, 05:04 PM
Bobs 84 300ZX's Avatar
It is most probably the throw out bearing. When press in on the clutch pedal, the throw out bearing is pushed against the "fingers" of the clutch plate. The pressure on the bearing will close up worn tolerances within the bearing and usually quiet it down. When no pressure is placed on the throw out bearing, the loose tolerances or worn races or ***** will become much louder. I agree with zxguy1986.
Thanks, Bob
Bobs 84 300ZX is offline
Old 09-17-2016, 08:35 PM
86tcoupe's Avatar
maybe Bobs 84 or a imput shaft bearing
does it change when you bearly pressure the clutch pedal
what does it do when RPM's at 4K
86tcoupe is offline
decalservice
08-26-2012 12:16 AM
JSimpson
FS: 300ZX (90-96)
07-25-2011 10:59 PM
Jamie Q.
350Z Performance / Technical
04-07-2011 03:32 PM
86z31drifter
17
01-06-2007 07:00 PM
jtmny1999
01-18-2004 09:04 PM
Quick Reply: 300ZX (Z31) Clutch sound
