!Vibration in steering wheel~ - ZDriver.com
Reply
LinkBack Thread Tools Search this Thread
Old 02-14-2013, 06:32 AM   #1
Red face !Vibration in steering wheel~
The past few days i've noticed vibration in the steering wheel in my 88 z31.. When I accelerate, it vibrates somewhat heavily. When I brake, it vibrates but I heard my rotars might need turned? Anyways, help! Thanks
Evan Faris is offline   Reply With Quote
Old 02-14-2013, 07:27 AM   #2
Warped rotors only vibrate the steering wheel when you are braking.
Get your wheels re-balanced.
And click: How-to: Diagnosing tire / wheel / chassis vibrations
NismoPick is offline   Reply With Quote
Old 02-15-2013, 08:01 AM   #3
Ok. Can you switch tires all around when you want? I'm wanting to switch like the back left tire with the front left? My back rear tire is getting bald in the inside of the tire and I figured that I would switch both rears and same with the front. Will that throw the steering off?
Old 02-15-2013, 08:01 AM   #4
Btw, my rotars are all new around as of 3 months or so ago.. I still have a warranty for them..
Old 02-15-2013, 08:49 AM   #5
Quote:
Quote:
Your rotors are not the problem for the acceleration shake, and unless you've been riding your brakes, or got them REALLY hot, they are not warped, and are not the brake shake problem. So, have you been riding your brakes? Do you drive down a lot of steep streets?
Yes.
As long as the both L & R are the same size, it won't throw off steering.
As I stated before, get them re-balanced. If you hit / nudged a curb, pothole, or bump, you could have lost a wheel weight, causing the shake. Also make sure all lugs are tight.
Old 02-15-2013, 04:19 PM   #6
ok and my rotars vibrate when i slow down.. the steering wheel shakes when i brake.. when i accelerate, the steering wheel shakes.. my friend who has 4 Z's says my tie rod ends might be changed?
Old 02-15-2013, 08:50 PM   #7
Speechless
Old 05-03-2013, 05:22 AM   #8
maybe u got some worn out bushings also
turbotim is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
My Re-Done Steering Wheel Donn144 300ZX (Z31) Forums 5 02-12-2014 09:35 PM
My 88' 300ZX steering wheel vibration when accelerating. Purple_EnvyZ31 300ZX (Z31) Brakes, Wheels, Suspension and Chassis 3 03-01-2013 11:45 AM
Steering vibration mrprofile 280ZX (S130) Forums 5 05-19-2011 08:09 PM
Steering wheel.. Zpeed Racer 300ZX (Z32) Performance / Technical 8 10-10-2003 01:43 PM
steering wheel Skully 240Z, 260Z, 280Z (S30) Forums 11 05-15-2003 04:15 PM
Tags
300zx, bald, make, tires, vibrate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright 2000 - 2014 ZDRIVER.COM All Rights Reserved.
