New owner, first up: suspension!
Old 06-25-2013, 02:19 PM
jeff1986's Avatar
Hey all, have had my 1986 N/A Z31 for two weeks today, great car.
Am taking it into my mechanic on Thursday for the rack/pinion and passenger side front wheel bearings, and I also need front struts.
So, 1st, should I do this all at once, then get the alignment and be done? Or can I just do the rack/pinion and bearings now, get an alignment, and do the struts later without needing another alignment?
And, whether I need struts now or soon, what kind should I get? Auto Zone has heavy duty Bilsteins for $125/ea that I'm eyeballing, generics for under $60 that I'd rather stay away from
Looking at some technical stuff, though, the 1986 N/A got fixed struts, while the turbo got larger and adjustable struts. Going by the maxim that when replacing, upgrade, I was wondering what all my options might be. So I can know what to ask for, rather than just going with what the Auto Zone computer recommends.
jeff1986 is offline
Old 06-25-2013, 06:29 PM
Grumpy & Helpful
rogerz's Avatar
rack and pinion doesn't have any bearings to replace. unless it is leaking you shouldn't touch it unless it needs new bushings and is sliding back and forth. HOW MUCH DO YOU TRUST THIS MECHANIC. You sound like here I am take my money as I know nothing. here are some things that are critical on the z31
Clean the connectors for the maf or afm, ecu and tps. Deoxit by CAIG is probably the best connector cleaner on the market. spray with CorrosionX after cleaning and before putting together this will help prevent any further corrosion.
Replace outer tie rod ends, and ball joints. replace the bushings with poly (don't forget to lube them as directed unless you like squeaky things). New shocks. all those things will make you think you are driving a different car. doing them piece meal is a waste you won't see a great improvement until you do the complete job. Rear bushings nice too but more work and you won't notice as great an improvement. Rear shocks also because if the fronts are gone so are the rears. if car squats when you jump on the gas the rears are gone. If you have the electro adjustable shocks they are DEFINITELY GONE.
anytime you mess with the suspension you need to get the alignment checked
If you can afford bilstein then fine but tokico or nyk work just as well unless you are keeping the car for 10years. (unlikely). The strut comprises the shock and the spring. you don't need a complete assembly.
rogerz is offline
Old 06-25-2013, 06:44 PM
jeff1986's Avatar
yeah, the driver's side boot is torn on the rack, and I go through a bottle of stop-leak psf a week or so. But the bearings are for the front passenger wheel, a lot of wobble there on both axes.
And I trust this mechanic. Have known him for a while, and my dad was a mechanic, so I think I'm good there.
New battery and clean terminals, but I'll make sure everything gets double checked on Thurs, good to know I have to be especially careful with the electrics.
Any idea where I can pick up just the front bushings?
jeff1986 is offline
Old 06-25-2013, 08:02 PM
Grumpy & Helpful
rogerz's Avatar
just get the whole set from motorsports. it has only the the rear sway bar included but all you need for the front except the rack. if it is leaking that bad you might as well get a rebuilt rack should be around $200. replacing the boot won't do a thing. one of the seals is shot. also you might want to read the manual. z steering systems use atf not psf.
rogerz is offline
Old 06-26-2013, 08:12 AM
jeff1986's Avatar
Thanks for sharing the wisdom/experience! Yes, this is the first car I've owned that I actually care about. '80 Malibu (the Boat), '86 Cavalier hatch, '90 Tercel hatch (manual), '98 Corolla, '92 Thunderbird (girlfriend's dad's car originally), '96 F-150 (farm truck).... hmm, I've also never had a car newer than '98... Never had the manuals for any of those.
But this one's a keeper. I feel lucky to have had the chance to buy it. I downloaded the pdf manual, though reading it I don't think it's just for the 1986 N/A, my car. I need to get a hard copy of the manual, too, and hope I'll be able to find one which is more specific.
Got the bushings on order, so instead of doing the front suspension (so I can wait for the bushings to get here) this week, I'll have my mechanic try to work out the vacuum hoses (hot air constantly blows once car's up to temp) and oxygen sensor (starts rough when the car is hot), maybe the oil pressure sensor (doesn't work) and check engine light (bulb is out) too. And check computer codes, see if any have come up.
jeff1986 is offline
Old 06-26-2013, 09:35 AM
Grumpy & Helpful
rogerz's Avatar
hot air means your water control valve on the firewall engine side is not getting vacuum. No vacuum fails to wide open. check all the small vacuum hoses going to the vacuum tank up front right side by rad. download the fsm from xenon web site. it has the vac diagram in it as well as a load of vital information. Your mechanic should have it or he shouldn't even touch the outside of the car. You can also get a CD version from courtesy Nissan (good source for parts).
z31 doesn't have a CHECK ENGINE LIGHT. there are a series of lights to show status of oil, coolant battery door open etc. in the manual.
you have to pull out the center pod to change light bulbs. its a little tricky to get out as you have to stand on your head to get at two 10mm nuts
rough start hot two possibilities most likely the cyl head temp sensor chts. cheap easy replacement. O2 sensor out car probably wouldn't run when hot. oil press sensor cheap easy replacement. ground the wire to the unit with ignition on. if the gage doesn't pin out then bad gage but sensor common problem. you got digital or analog dash? different problems and solutions. Does bitchin betty work?
check AZbum website for some great info.
rogerz is offline
Old 06-26-2013, 12:27 PM
jeff1986's Avatar
Well, so some of what the guy I bought it from said isn't accurate... I'm not too surprised, he only had it 2 months. He thought it had a check engine light but the bulb was out for some reason... I was just writing down everything he said for my mechanic to investigate.
And Bitchin' Betty works fine, or did until I removed the speaker...
And analog dash.
So, got the CHTS, tomorrow with mechanic I'll be:
checking&cleaning all connections
getting vacuum hoses straight
check computer for codes
replace CHTS if needed
checking & replacing as needed distributor, wires, and plugs... tune up stuff
maybe checking oil pressure sensor?
maybe checking/recharging ac
maybe checking/fixing pass door window (doesn't like to go up and down, motor sounds like it's working...)
also taking a ride to listen for a kind of harmonic/sympathetic vibration that sounds light and fairly high pitch, metallic, possibly engine something? Which appears mainly at certain RPMs (2000 or so, again at 3000, not higher, not when I'm really gassing it) and more when running hot...
jeff1986 is offline
Old 06-27-2013, 05:13 PM
Grumpy & Helpful
rogerz's Avatar
window circuit is often the switch. they have a leaf spring in there to make contact and it gets tired.
you can email me at krs@whidbey.com
easier than passing stuff on the forum. I've done three z31 (turbos) know a bunch about the beasts. 86 is my favorite
rogerz is offline
khass0410
06-26-2015 08:51 PM
goodlifting
09-18-2011 09:35 PM
xXEliteTuningXx
08-23-2011 05:54 AM
Julya-zombie
07-23-2011 10:12 PM
Dante
01-30-2004 06:44 AM
Quick Reply: New owner, first up: suspension!
