!Vibration in steering wheel~
Old 02-14-2013, 05:32 AM
Evan Faris's Avatar
Red face !Vibration in steering wheel~
The past few days i've noticed vibration in the steering wheel in my 88 z31.. When I accelerate, it vibrates somewhat heavily. When I brake, it vibrates but I heard my rotars might need turned? Anyways, help! Thanks
Evan Faris is offline
Old 02-14-2013, 06:27 AM
Warped rotors only vibrate the steering wheel when you are braking.
Get your wheels re-balanced.
And click: https://www.zdriver.com/forums/tire-...rations-36311/
NismoPick is offline
Old 02-15-2013, 07:01 AM
Evan Faris's Avatar
Ok. Can you switch tires all around when you want? I'm wanting to switch like the back left tire with the front left? My back rear tire is getting bald in the inside of the tire and I figured that I would switch both rears and same with the front. Will that throw the steering off?
Evan Faris's Avatar
Btw, my rotars are all new around as of 3 months or so ago.. I still have a warranty for them..
Old 02-15-2013, 07:49 AM
Your rotors are not the problem for the acceleration shake, and unless you've been riding your brakes, or got them REALLY hot, they are not warped, and are not the brake shake problem. So, have you been riding your brakes? Do you drive down a lot of steep streets?
Yes.
As long as the both L & R are the same size, it won't throw off steering.
As I stated before, get them re-balanced. If you hit / nudged a curb, pothole, or bump, you could have lost a wheel weight, causing the shake. Also make sure all lugs are tight.
Old 02-15-2013, 03:19 PM
Evan Faris's Avatar
ok and my rotars vibrate when i slow down.. the steering wheel shakes when i brake.. when i accelerate, the steering wheel shakes.. my friend who has 4 Z's says my tie rod ends might be changed?
Old 02-15-2013, 07:50 PM
Speechless
Old 05-03-2013, 04:22 AM
turbotim's Avatar
maybe u got some worn out bushings also
turbotim is offline
Donn144
02-12-2014 08:35 PM
Purple_EnvyZ31
03-01-2013 10:45 AM
mrprofile
05-19-2011 07:09 PM
Zpeed Racer
10-10-2003 12:43 PM
Skully
05-15-2003 03:15 PM
Quick Reply: !Vibration in steering wheel~
