Brake Caliper Rattling/Drag noise
Old 03-15-2015, 12:03 AM
steezy300's Avatar
Exclamation Brake Caliper Rattling/Drag noise
hey i have an 87 300zx z31 turbo i bought the car a few months back and recently i came across this problem shorty after doing a full brake job where my rear right brake caliper started dragging and making this loud rattling noise. So i ended up replacing it and that solved my dragging brake problem, but then the rattling noise came back. Ive been trying to find out but i had no luck. Have any of you experienced This? If So can you offer any suggestions or solutions to my problem.
steezy300 is offline
Old 03-16-2015, 10:42 AM
Grumpy & Helpful
rogerz's Avatar
take the calipers apart and be sure they are clean and lubricated (silicon grease only)
OR
Amazon.com: Raybestos FRC3640 Professional Grade Remanufactured, Semi-Loaded Disc Brake Caliper: Automotive Amazon.com: Raybestos FRC3640 Professional Grade Remanufactured, Semi-Loaded Disc Brake Caliper: Automotive
rogerz is offline
Old 07-01-2015, 07:57 AM
Desert Rat's Avatar
I have a similar issue - driver side.
Dragging. I pulled the rear wheel to find my nearly new ceramic brake pads just about totally used up. (guess that explains the drop in MPG lately).
Calipers are reman'd units that I installed back in December, so I'm hoping it's not those. You can bet I'll be back at the parts store getting a warranty replacement if it is. I just hate bleeding brakes, and the wife bitches when she has to come out and pump the pedal for me.
If it's a sticking E brake cable, I'm hoping it releases as soon as I disconnect it. It's been 110 degrees plus, and I just discovered this when I got home from work yesterday so I'll tear into it this weekend.
Also have a newly torn CV boot No one, and I mean NO ONE has reman'd CV shafts for this so I guess I'm redoing the boots too. The torn boot made a mess under the car that'll take a can of brake cleaner to get cleaned up....all over the muffler too, so it stinks.
Desert Rat is offline
Eric9006
09-15-2014 04:18 PM
Sixer
04-14-2010 05:29 PM
MO3IUSONE
12-30-2008 05:11 AM
HaulinZ
02-26-2006 11:23 PM
kolts
09-25-2002 05:59 AM
Quick Reply: Brake Caliper Rattling/Drag noise
