Stance Coilover Rear Adapter Kit
So, you're thinking about adapting S13 coilovers to your Z31, and realize it's going to be a bit of a tough task?
We've worked out a solution for owners to be able to take care of the rear conversion with this kit.
There is no fabrication needed, just a few simple tools and you are ready. This will work with any Stance coilover kits for the S13 that use a upper rubber isolator (will not work for kits with spherical bearings).
The kit comes with rear lower adapters, as well as rear upper bolt-in mount adapters, as well as hardware to bolt the upper adapter to your car. (You will need to retain the mounting fasteners for your Stance coilover to mount it to the adapter plate.)
What do you guys think? There are several cars who are running this kit, and no one has reported issues thus far.
onelegmurphy
03-24-2003 04:11 PM
