New wheels..
Old 08-26-2013, 03:48 PM
Evan Faris's Avatar
New wheels..
Ok i've done my research and haven't found anything else.. I'm running 225/40/18 tires now.. Wanting to go to 205/50/16s.. Stock 88 NA's run 215/60/15... Some people have told me that the 205/50/16s might not clear the brake caliper properly and won't work. Anyway someone could tell me if they would or not? Nowhere else to search..
Evan Faris is offline
Old 08-26-2013, 06:39 PM
Zdon's Avatar
Wheel size and clearance
It's actually the reverse, but that would be going from a 15" inch to a 14" inch, but from 15" inch to an 18" no problem. Now going back from 18" inch to 16" inch no problem unless you have done some modification to the front end, such as bump steer spacers, or bigger calipers etc. Other than that you're god to go.
Zdon is offline
Old 08-26-2013, 07:58 PM
ken99's Avatar
Why 205/50R16?
Why 205/50R16? This size is narrower than either stock size and has a rolling circumference more than 3" shorter, which means a smaller contact patch. IF you wish to revert back to a smaller wheel size, I'd use one of the stock sizes. The turbo size has a slightly larger contact patch and slightly shorter side wall, but otherwise there isn't much difference between the 225/50R16 and 215/60R15 tires. The NA cars have a fairly large offset tolerance. Any 7" wide rim with an offset of +20 to +40 should work just fine. To simultaneously compare two tire sizes to one another, use a tire size calculator.
Read ZBUM's information page on wheels and tires to understand what works best for sizes.
ken99 is offline
Old 08-27-2013, 03:26 AM
Evan Faris's Avatar
Figured it'd be a complete waste of time. Thanks.
Old 08-27-2013, 07:13 AM
ken99's Avatar
Gee, I'm sorry. I thought both ZDON and I had provided answers to help you decide which tire size would work best. So...Yes, the 205/50R16 tire will work just fine on your Z31 NA with a stock suspension, provided they are installed on right rims. Look for 16 x 6.5J or 16 x 7.0J wheels, +20 to +40 offset and with a 5x114 bolt pattern.
ken99 is offline
Old 08-27-2013, 02:14 PM
If you Facebook: https://www.facebook.com/photo.php?f...type=1&theater
NismoPick is offline
Old 08-27-2013, 04:59 PM
ken99's Avatar
If you Facebook:....
Yes, why bother.
ken99 is offline
Old 09-02-2013, 02:47 AM
AZ-ZBum's Avatar
Offset determines a lot. Spoke design determines most. Tire size is bullshit number to say if they'll fit or not. 205 is narrower than stock = it will fit. But offset will really be the deciding factor.
If "some people" really did tell you 205/50/16 won't fit, then they're even dumber than you are.
AZ-ZBum is offline
Old 09-04-2013, 11:46 PM
samsniss350z's Avatar
I personally think you'll struggle.
samsniss350z is offline
borini63
07-29-2013 05:30 AM
LowdedZ
FS: 300ZX (90-96)
03-04-2005 08:16 AM
300ZXRat
06-25-2003 08:53 AM
twinhairdryers
06-21-2003 06:24 PM
Quick Reply: New wheels..
