!Vibration in steering wheel~
The past few days i've noticed vibration in the steering wheel in my 88 z31.. When I accelerate, it vibrates somewhat heavily. When I brake, it vibrates but I heard my rotars might need turned? Anyways, help! Thanks
Warped rotors only vibrate the steering wheel when you are braking.
Get your wheels re-balanced.
And click: https://www.zdriver.com/forums/tire-...rations-36311/
Ok. Can you switch tires all around when you want? I'm wanting to switch like the back left tire with the front left? My back rear tire is getting bald in the inside of the tire and I figured that I would switch both rears and same with the front. Will that throw the steering off?
Yes.
As I stated before, get them re-balanced. If you hit / nudged a curb, pothole, or bump, you could have lost a wheel weight, causing the shake. Also make sure all lugs are tight.
ok and my rotars vibrate when i slow down.. the steering wheel shakes when i brake.. when i accelerate, the steering wheel shakes.. my friend who has 4 Z's says my tie rod ends might be changed?
Speechless
Speechless
Purple_EnvyZ31
03-01-2013 10:45 AM
