Need help with rust
Old 04-25-2015, 11:04 AM
ETHoward's Avatar
Need help with rust
Hello, I bought my first car and it was a 300zx and it has some issues and I was looking for some help, Biggest issue now that i have is lost of rust. Just last week I bought a replacement gas tank and wiper motor and got them installed and working! Now i have to take care of the rust. The guy before me did not do a good job taking car of the body tho i bought the car extremely cheap cause of the rust, all i need to do is fix the rocker panels and along the floor next to the seats cause it rusted through and i was wondering what would be the best solution for it. Also another question is the back brake lights stay on and i can't figure out why they are staying on, the guy before me installed a switch like thing on the box with wires like looping up and its next to the battery and i have to flip it so i can have my lights on and stuff tho it will run with out it on. (sorry I don't know the name of it but I'm just getting started with automobiles) Thanks for the help!
ETHoward is offline
Old 04-25-2015, 05:04 PM
Zuphoria's Avatar
post in the right fn thread
Zuphoria is offline
Old 04-25-2015, 05:14 PM
Skully's Avatar
Dealing with rust. First pretty much gut the car, remove anything and everything from it. Start by cleaning up the metal, this will tell you how far the rust has gone into the body. You need to be able to access everything. If you just mask it, patch weld it, it will come back just as bad. If you keep the carpet and interior pieces in while you try to do any cutting and welding, you will set something on fire, or melt most of your plastic and rubber anyways. You need to pretty much strip the car and go from there. Rust is not a small task to take on for sure. As far as your brake lights go, could be simple as the switch under the brake pedal, or one thousand shorts somewhere in the rusted wiring. If your rockers and floors are rusted through, you can bet your *** there is rust in places that aren't openly visible due to interior, and trim.
Strip and start all over, or get a new donor shell that is clean. Rust is cancer, either cut it all out and replace, or you will never get rid of it. Also x2 on posting in the right section.
Nismo can you move this over to the right section maybe, thanks.
Skully is offline
Old 04-25-2015, 05:29 PM
ETHoward's Avatar
Oh sorry, I'm new to the site and go ahead move the this forum. And the carpeting was tooken out before i got the car same with all the panels, i will need new carpeting any idea where i can find that for a decent price. And i have a parts car that i got a week ago tho i don't have a welder. I was just wondering how to clean up the rust and cover up the holes.
ETHoward is offline
Old 04-25-2015, 09:48 PM
ken99's Avatar
Common issue.
Z31 Brake Lamps Always On
ken99 is offline
Old 04-26-2015, 05:52 AM
ETHoward's Avatar
Okay cool thanks
ETHoward is offline
Old 04-26-2015, 10:59 AM
ken99's Avatar
The last time I fixed this problem, I went down to the local hardware store and found they had a selection of plastic push pin retainers that looked something like the photo. I picked the size that held securely in the hole. I also took the time to adjust the switch plunger gap (may have been the cruse control switch I adjusted) back to 1mm since the plastic head of the retainer was thinner than the Nissan grommet it replaced. Seems to be working just fine.
ken99 is offline
Old 04-26-2015, 02:22 PM
ETHoward's Avatar
Alright tho I took out the cruise control cause I feel like its unnecessary weight in my car and I don't use it any ways.
ETHoward is offline
Old 04-26-2015, 03:25 PM
ETHoward's Avatar
Now something weird came up the fuel gauge stopped working and now when i turn on the car it makes like a buzzing noise from what i am guessing is the fuel level unit could it be that?
ETHoward is offline
Old 05-07-2015, 06:45 PM
masterhufflpuff's Avatar
It sounds like, most likely, that noise you're hearing is your fuel pump priming, which is normal. It should prime for 5 seconds when you turn the key to "on." Is that what's happening? or is it a continuous noise?
masterhufflpuff is offline
Old 05-10-2015, 08:18 AM
ETHoward's Avatar
its continuous
ETHoward is offline
Old 05-10-2015, 10:14 AM
hm, it sounds like maybe your pump isn't shutting off when it's supposed to. What happens when you start the car?
Old 05-11-2015, 03:21 PM
ETHoward's Avatar
The noise still happens its coming from the gas tank so it must be the pump but i also hear something from a little white box on the rear light
ETHoward is offline
Old 05-11-2015, 09:17 PM
Pump relay probably went out causing the pump to stay running, that would be my first guess. Can you start the car? and see how it runs?
Can you take a picture of this white box making noise?
Old 05-12-2015, 01:03 PM
ETHoward's Avatar
yes the car starts but from what i can tell now its coming from the fuel pump gauge cause my fuel gauge on my dash is saying its on empty when i know i put 10 gallons of gas in and i finally got my haynes repair manual in and that white box is the tail light sensor from what i read up on.
ETHoward is offline
GOLDNZX
02-13-2012 07:13 AM
PredatorZ
01-24-2012 06:37 AM
master300zx
04-10-2006 08:50 PM
Spak339
04-05-2004 02:42 PM
lathrop1000
03-29-2003 10:56 PM
Quick Reply: Need help with rust
