digi tachometer issue
Old 03-25-2014, 10:29 AM
mjoseph229's Avatar
Hi guys! My digi dash tachometer Is doing something weird after an engine overhaul. The lines that move up and down with pedal movement are stuck as if I am holding down the accelerator. The lines never come down like the gas pedal is being held down. It did not do this before the overhaul. How can I fix this?
mjoseph229 is offline
Old 03-25-2014, 11:10 AM
Grumpy & Helpful
rogerz's Avatar
on a turbo they show boost. sensor is on the left front wheel well inside the engine compt.
May be the same on n/a. look for rectangular black box says something like boost sensor or some such.
may be disconnected electrically or vac hose is detached.
rogerz is offline
Old 03-25-2014, 06:53 PM
FlyingT's Avatar
Yeah, sounds like a possible vacuum problem or sensor problem. How is the car running? Climate Control working properly?
FlyingT is offline
Old 03-25-2014, 10:55 PM
mjoseph229's Avatar
car runs good and climate control dont work cause of fuse blows out. that is a different issue. i will check on that black box plug this weekend and post results. thanks guys. BTW its a turbo z
Old 03-30-2014, 02:52 PM
mjoseph229's Avatar
Ok i been looking for this black box on the passenger side wheel well and cannot not identify the boost sensor. Can someone put up a picture of the sensor so i can see if the problem is a bad hose or electric connection issue?
Old 03-30-2014, 03:30 PM
PredatorZ's Avatar
What car ?
You never posted details, what year car ? What options, everyone must be psychic ? Just because you post in the z31 forum, all the years vary, so you must tell us the year engine and trim package to get correct help.
PredatorZ is offline
Old 03-30-2014, 03:35 PM
mjoseph229's Avatar
sorry 1985 300zx turbo. i found the boost sensor on the driver side under the ignition coil but no hose is connected or near it. Where on the manifold does the other end of the hose connects to from the sensor?
Old 03-30-2014, 04:50 PM
PredatorZ's Avatar
run a line
There has to be an open T or free connector close, most likely just needs manifold vacuum, if you need to, go to a parts store, get some vacuum line and some T's in the accessories section and add a line in. In the FSM is a test for the sensor, it is in the electrical section, meters and gauges, digital combo meter, boost sensor check
Old 03-30-2014, 05:39 PM
Grumpy & Helpful
rogerz's Avatar
why in the ten thousand names of god would you look on the passenger side when I said it is on the left??? even if RHD left is still left. you will probably find an unused spud for the hose after the throttle body. if left unplugged doesn't help the running of the car. vacuum leaks are the bane of the FI engine
rogerz is offline
PredatorZ
FS: 300ZX (84-89)
07-29-2014 07:21 PM
ninjataco
09-10-2011 10:59 AM
Seraphic
02-21-2005 06:23 PM
Spot
01-30-2002 07:48 AM
Quick Reply: digi tachometer issue
