please help!
Old 03-12-2017, 03:45 PM
chrisc's Avatar
please help!
Hello all idk if im using this site right but here it goes i just picked up at 1981 280zx its my dream car dont know much about working on cars though. My problem is when i start the car its fine then i tapthe throttle and it sounds hesitant and backfires i unplugged the maf and it runs real rough when i do that but dosent die the tps is missing a screw when i drive it it will block me anywhere from 2500 to 4k rpm any thoughts ? Thanks.
chrisc is offline
Old 03-12-2017, 11:17 PM
JAyD_917's Avatar
I would do the basics like check/ replace the old hoses to ensure there are no vacuum leaks, plugs etc. but honesty I'm pretty sure you're having a problem with the fuel system being clogged. Drop the tank and inspect it and the inline filter. Install a clear fuel filter between the tank and fuel pump(to monitor the quality of gas/gunk) and maybe swap the pump with a cheap rockauto one for now while you're at it(nvr hurts to have an extra one around, trust me), put in a new fuel filter too. Prior to doing all that though, it may be more convenient to check/get a fuel pressure gauge and check that.
One rare thing couple be the fuel pressure damper. I have 4 zx's and I didn't even know the part existed until one failed on mine recently and began leaking. Best advice is don't throw parts at her unnecessarily. Welcome to your new addiction... or enemy.
JAyD_917 is offline
Old 03-13-2017, 06:22 AM
chrisc's Avatar
Thanks for the help ill take your advice
chrisc is offline
87300ZZzz
02-06-2013 05:37 PM
harissanja
12-17-2006 09:29 PM
nissianimport420
11-07-2001 12:43 PM
dcg9381
02-18-2001 03:21 PM
Quick Reply: please help!
