81 280zxt w/ z31 ecu maf issues
Old 10-26-2014, 06:36 PM
datsun280zxt's Avatar
Ok i worked on my 81 zxturbo with z31 ecu maf.. when floored it goes to 3-4k and starts poping like Fireworks but if i accel slowly it goes all the way to 5-6k.. when it pops gauge shows rich mixture.. rechecked valve adjustment replaced rotor cap.. it seams like its not getting enough air or spark.. black smokes comes out.. need help
datsun280zxt is offline
Old 10-29-2014, 01:06 PM
Still haven't found the problem on Jarom's car either...
New MAF, coil, ignitor, and all new EFI wiring. I will be swapping in a VG30E CAS and different turbo injectors this week...
NismoPick is offline
Old 10-29-2014, 11:27 PM
borini63's Avatar
Fuel pump?
borini63 is offline
Old 11-06-2014, 06:52 AM
This was discussed on FB... not sure if he fixed it yet, but on Jarom's car that I've been working on it was a combination of 3 things:
-Camshaft sprocket was 1 tooth off
-Distributor shaft was 1 tooth off
-Faulty CAS in the distributor
Fixed the timing and replaced the CAS with one from a Z31 and it runs great.
I know datsun280zxt (Guillermo) didn't have the timing mark plate attached to the timing cover, so he couldn't even check the timing. He said he was going to reinstall it.
81turbocoupetx
12-19-2012 02:56 PM
Drunken Crooner
10-08-2012 10:17 AM
ricksilvia
08-04-2012 05:40 PM
nismo619
11-10-2005 10:23 PM
280 drooler
07-16-2003 11:48 AM
Quick Reply: 81 280zxt w/ z31 ecu maf issues
