Tail Lights won't shut off
Old 11-16-2007, 02:32 AM
iielmosglueii's Avatar
After getting home from work I find out that my tail lights don't shut off when I turn off the lights. Key is out of the ignition and it still remains on. Brake lights aren't functioning also. Can anyone help with this problem?
iielmosglueii is offline
Old 11-16-2007, 07:48 AM
Spraguepsycho1's Avatar
Sounds like the brake lights are on, check the brake pedal. There is a switch that contacts the pedal up under the dash when you take your foot off the brake and turns off the brake lights. There's supposed to be some kind of pad on the pedal arm where it contacts the switch, if that falls off, the switch lines up perfectly with a hole in the arm. I had the same problem on my '79, so I just made a sheetmetal clip and popped it onto the arm to push the switch, and the lights work fine now. You may even be able to just superglue or epoxy a old penny over the hole and it should work.
Spraguepsycho1 is offline
Old 11-16-2007, 09:28 AM
Doesn't post much...
RodMoyes's Avatar
We just had a thread about this same problem a couple of weeks ago. The "Search" feature is there to help you...
https://www.zdriver.com/forums/280zx-s130-forums-77/brake-light-23869/
Anyway's... Yeah, it's your brake light switch as stated above.
Rod.
RodMoyes is offline
Old 11-16-2007, 09:41 AM
chinesekid's Avatar
yup, i just did it two weeks ago..
chinesekid is offline
Old 12-04-2007, 03:00 AM
BigEkak1941's Avatar
You can do any of the solutions above and it will fix the problem. I had the same problem and just went to the dealer for the plastic part. You will be surprised at some of the parts you can still get for a 280ZX (we have several Z's), and I am amaized at what people sell new on eBay for high prices when you can still get it from the dealer. Have a great one.
BigEkak1941 is offline
Old 12-06-2007, 02:02 AM
Wow you guys replied quick. Yeah I just looked up the post with chinese kid and was gonna delete this one. But yeah, thanks for the help guys
Old 12-06-2007, 06:55 AM
From your dupe thread:
Originally Posted by iielmosglueii
Alright guys I have a problem with my rear tail lights. They won't shut off when I turn the lights off and key out of the ignition
The ignition doesn't have anything to do w/ the prob... these are old cars. You can turn on all lights w/ no key. Is it ONLY the tail lights that stay on? Because all the side markers & tails are wired together... if the tails are on, so should be the side markers...
and the break lights won't work ethier? Can anyone help with this. I'd appreciate it.
As discussed above, check the brake switch.
NismoPick is offline
Old 12-09-2007, 10:28 PM
its just the tail lights left on. side markers go off.
Old 12-09-2007, 10:36 PM
The Cake Is A Lie!
entropy31's Avatar
it's the brake lights.
entropy31 is offline
Old 12-09-2007, 10:49 PM
I'm a Registered User!
SpeciallySpiked's Avatar
Did you fix it?
SpeciallySpiked is offline
Old 12-10-2007, 01:15 AM
no not yet heh
Old 12-10-2007, 11:11 AM
This thread is like pulling teeth.
Old 12-11-2007, 05:39 PM
User Friendly
Z Car Barbie's Avatar
LOL!
Iielmosglueii, look in the driver's side floor board for little chunks of plastic. That's a sure sign that you need to replace the little spacer. They tend to break after several years, and without it, your brake pedal is making contact with the brake switch, which causes the tail lights to stay on.
The only equipment you will need to replace it is the new spacer itself and a flashlight.
Z Car Barbie is offline
Old 01-13-2008, 12:21 PM
Just for info, I was able to get the plastic plugs at the dealer. If you can't get it just cut a small piece of sheet metal, fold then clip over the hole on the peddle bracket as that will work also.
Old 01-16-2008, 12:29 AM
i used a nut and tape sometimes it falls off but i just fix it. hah. thanks for the info though!
Old 02-12-2008, 07:11 AM
nismo619's Avatar
i had the same problem with my 82 zxt 2 of the plastic rubber peaces craked off the bake pedtal located underneath the dash were the petal meets the metal. u will have to get low with a flash light and get the replacment parts thank god i had a few 280zx's parts left in my shead...
nismo619 is offline
Old 02-12-2008, 08:35 AM
Whoa! is that really how you fix the problem?
I never would have guessed that from reading the thread already...
Silvermachine
01-21-2015 09:00 PM
Murph Z32
25
10-07-2012 08:07 PM
kr11zzz31
09-08-2011 07:39 PM
ZCHondaCRX91
05-19-2011 07:34 PM
norrbr
04-17-2004 10:53 PM
Quick Reply: Tail Lights won't shut off
