VH45DE swap
#153
I have a present for you...
Found out the same seller now has 10" fans for the same price, doh!
DUAL 10" INCH ELECTRIC FAN & THERMOSTAT RELAY | eBay
#154
Thanks
#156
The stock headers won't work in the S30 chassis without hitting the firewall. I cut them up to use as mockup for the stainless tubes. I might use flexible stainless exhaust tubing from the flanges to the collectors.
#160
#162
There's a chopped down roof S30 in a Z grave yard around here. Vertically from the top of the door to roof line is less than 1ft. Looks pretty crazy... I think they were going for the ratrod approach, but didn't work out. I'll try to get a pic sometime.
#163
Interesting. It would be quite an undertaking. It's not that hard with PhotoImpression lol but when I sectioned the picture it gave me some ideas of how to do it for real. Hope you can find the post, I don't remember ever seeing it. The speedster would be easier.
#164
Time flies and nothing done. I did get a Walbro 255L fuel pump and I just scored a 12 circuit Painless wiring harness. So I'm just going to yank the old harness.
#165
Went to picknpull for 1/2 price day. Got these cv axles and hubs out of a '91 Infinity M30. Got some Maxima rear calipers for a rear disc conversion. I did this on my "70 but I used 280zx calipers. Here is a pic of the brackets i used to make.
#167
I am going to use the stock ones. I will have to bore them out to fit the larger bearings. It's about .010. I will have to section about 1/2 or more out of the companion hubs because the axles are longer. Not sure how much but the width of the 280zx and M30 are 2 1/2" wider than the S30. I might go with the 300zx 5 lug stub axles.
#169
vlsd
When I was at picknpull I didn't notice the yellow dot by the fill plug on the diff. I looked it up on the web to find out what gear ratio it might have. Turns out they all have 3.9 vlsd!!! Went back today and snagged it for $100. Now I will have a robust set up for smokin both tires.
#170
http://www.cardomain.com/ride/645045/1973-datsun-240z/
#172
Well guys I havn't had much time to work on my car and I'm still having trouble deciding on which bottle throtty, I mean throtty booty, I mean fondle body, I mean-
