Weird Carb Linkage
Weird Carb Linkage
I just bought a 1973 240Z last weekend, and I have been going through it, getting it road worthy.
I spent last weekend tearing apart the carburetors, and I finally got them all cleaned up and put on tonight. The carb linkage seems a little strange, considering when I went to remove it, a zip tie was holding it down (see photo).
What is this? How SHOULD it be setup? There are 3 little L bars, but every image I see of 240Z's, there is only 2, and no screw.
Oh, these are '72 round top carbs obviously, the flat tops were ditched at some point by the original owner.
I have that same set up on my 260z. And that doesn't do anything as far as adjustments go. I believe it was connected to a part of the emissions that has been removed. So shouldn't effect carb tuning, at least it doesn't on mine.
Daniel
Daniel
The screw on the right is your idle adjustment, not the balance. That's the balance adjustment screw on the left.
Fiddle with your throttle linkage and you'll see it clearly. Adjusting the screw on the right will change the idle position of both carbs and the screw on the left changes the offset between the linkages of the two carbs (balance).
Round top carbs are the way to go btw. Be glad those flat tops are gone. You can get more information at ZTherapy.com. You can even call them for advice. Talk to Bruce, he's a good guy.
Here is a link to my Google+ album: https://plus.google.com/photos/11362...91694125428353
Jennings.brent6
05-30-2014 11:10 PM
