Thermo Housing cover
Does anyone have a source for the thermostat housing cover for a 76 280z?
I just dodged a huge bullet when I was trying to change the thermostat and replace the gaskets. I broke off one of the bolts that held the cover, then tried to remove the entire housing and one of those bolts broke off as well.
In the process of extracting the cover bolt, the easy-out expanded the bolt and cracked a corner of the cover.
I was just now able to get the broken bolt out of the side of the head... I had to use vise grips adjusted so tight that I had to use a C-clamp to close them.
So anyway, all the 'from bad to worse' bull**** seems to be over, but I have this thermostat housing cover that has a crack.
It's odd to me that these two parts, the housing and the housing cover are not easier to find... with the perfect storm of dissimilar metals, and perhaps a bit of coolant seepage under the gaskets, this would be a part that has considerable demand. OTOH, perhaps that is precisely the reason they are unicorns.
If anyone knows where I can find a cover I will buy the beers.
t
t
Nissan, or le junk yard. I believe I have a spare or two as well.
11061-P6521 - Genuine Nissan HOUSING-THERMOSTAT
11060-P6500 - Genuine Nissan OUTLET-WATER
http://nissan4u.com/parts/280zx/us_s...llustration_2/
Thanks, awesome.
it looks like this part on ebay will fit, but mine has three bolts (one unused).
http://www.ebay.com/itm/Datsun-240Z-260Z-280Z-1970-78-Coolant-Outlet-Neck-Thermostat-Housing-OEM-Nissan-/321570572817?pt=Motors_Car_Truck_Parts_Accessories&hash=item4adf198a11&vxp=mtr
Not sure if the zx part will fit yet.
Worst case, the crack is on the outside of the bolt hole, not the inside where the sealing surfaces are. Some JBWeld and creating use of a washer will probably get me back on track.
I have one from a '77 280z that should work but I can double check if you send me a picture of yours. You can email me at
88dangerdan@gmail.com
Daniel
Daniel
Daniel
Daniel
Cheers
3XAZOWNER
05-16-2006 11:30 AM
