PO cut the fuel rail?
Didnt really notice this before until I started this year's fall Z project, but the PO has hacked the fuel rail:
The masked nibs you see there are (from right) #1 and #2 injector. You cant see in the pic, but there are marks from a hacksaw where he took a couple tries at it. Perhaps he was impatient and was trying to take it off and decided to hack saw it. Anyway, these two cuts are not supposed to be there per the FSM, and if they were, they would have the proper nib style ends to securely hold a fuel line clamp.
While I'm not too concerned about leaks (it hasn't leaked in the 24 months I've owned it), I am a bit concerned that here is a section of fuel rail that is not secured to the manifold by anything other than two short pieces of fuel line hose.
If this was your L28, what would you do, if anything?
2 options
I would say there are 2 ways to go here, find a stock "trombone" fuel rail and use it, or have a custom rail made. Not sure if a rail from an 81 280zx would be compatible with your car, but I will soon have one available, I have ordered a custom fuel rail and it will be ready and shipped in the next day or so, so after I install it ill have no need for the old one. Not sure of the fit, perhaps Nismopick or one of the other Z guru's could give a definitive answer, I would give it away for just shipping charges, say about $ 20 shipped. Tips are excepted, you can always donate to my favorite charity "me"....
Jeff Thompson is the guy fabricating the rails, not sure what his sign on is here, but he is in several FB forums, like https://www.facebook.com/groups/164690436882353/
I see what you are saying, but if I can beg the question a bit, WHY does it need replaced?
A large question is WHY did PO cut it in the first place, but he long ago stopped responding to my texts....
reasons
I would say one reason, or concern with a rail in so many pieces, it just adds to the amount of possible connections that can leak, if all you need to do is put a few short pieces of hose in to get it all working, and you are good with that, it should be fine. I can kind of understand why it was cut up, when I 1st got my car, a lot of the rubber lines needed replacing, taking the fuel rail off in one piece involves removing a lot of stuff, it was most likely done in frustration, to speed up removal. You might want to get a flare tool, put some flares on the cut ends, so you don't have a fuel leak.. which turns into a 3 alarm fire.. bye bye car at that point. More of a safety issue if not done properly, that would be my major concern really, no leaks !
Yea, I will see about making some proper ends. It seems odd to me that I never noticed the extra set of hoses before. Now is the time to do it since I have the manifold and rail off.
Cheers.
Cheers.
new to z driver
Where can I find an aftermarket fuel rail setup for my 260z? I'm running dual webers and need a show quality fuel line / rail. I don't mind making one but due to time restraints, I would rather just buy one ouright. I appreciate any suggestions, ideas, pics or information. Thank you for your help.
and make a real nice fuel feed for not much $.
If you want one, you'll probably be making it out of stainless.
