My Defrost doesn't work
Old 11-18-2002, 02:56 PM
Re: My Defrost doesn't work
What year car do you have?
Is it the fan motor that is not turning on, or is it that your air flows out the vents toward you and not up at the windshield where you want it?
If it is a 75-78 Z, most likely there is an air leak. Those cars have a large plastic canister in front of the battery. That canister holds air vaccumme and pulls some levers to aim air up at the ducts for defrost. Mine had an old hose that was leaking. Replacing the air hose to that canister fixed the problem.
Bleach is offline
Old 11-19-2002, 08:11 AM
The hose is generic. You can buy a small reel of hose. I think its the same size of hose for the vaccume advance on your distributor.
As for the lever not moving all the way, please do open up your dash. You just need to take out the lower part, not the actual dashboard. One of those levers might be bent from someone forcing it or the cables might need some lubrication. You'll be so happy once it is all working smoothly.
Bleach is offline
todd5854
04-09-2014 10:42 AM
swlabr
02-07-2014 06:59 PM
Turbo86
04-25-2006 03:13 PM
albow2213
08-03-2002 08:56 PM
84turboz
04-24-2002 06:55 AM
Quick Reply: My Defrost doesn't work
