egr valve
Egr valve elimination pros and con
I like the word con because if you're in California and get caught without an egr valve you can be con-victed. It depends on the where you live and their smog laws. However a car without an egr valve gains at least 5-10hp but you'll have to eliminate the catalitic converter which will also give you more hp. Hope that helps.
BUT if your car does have to be smog checked, they will likely ding you for not having an EGR which may or may not fail you.
That is far from correct. The EGR isn't always active or passive. All it does is recirc a small amount of exhaust. Removing the EGR does not increase HP, nor does it also require removing the cat.
Alright... trying not to go overboard on this one...
USUALLY, yes.
As I previously stated, the EGR isn't always active. Just throwing out a random " +5-10hp " statement like that doesn't mean it's true. You should learn how and when an EGR works before assuming that removing it magically adds 10hp (which is an extreme stretch no matter what).
And again, removing the EGR and removing the cat are two unrelated things. You do not "have" to remove the cat when you remove the EGR... again the EGR isn't always functioning.
Arg... just open the FSM sometime.
thanks.... everyone for the replys.. not looking for any hp on this one....im doing the head gasket and also looking at cleaning up the intake a little.. just don't like to take things off that may effect other things.......
yoshi8976
09-05-2003 05:35 PM
haktmal
04-20-2003 06:59 PM
