want to put a/c on my 260 w/ 240 carbs
Originally Posted by OlderThanMe
I can tell that my 260 had a/c before the carb transformation to the 240z carbs because there is an extra pully on the front of the engine. Can I put a/c on my z and what would be involved?
Guest
Posts: n/a
yes, please post some photos! thanx
the only thing is if the my carbs have somthing to do with the a/c then their may not be some hook-up that might be needed. Then if so mabey I can install a/c from a 240z if they had a/c with my type of carbs. the carbs are the early 70-71 style SU carbs
260/ac
a/c on your 260Z
Guest
Posts: n/a
I do not have any of that but I have the plug that the harness plugs into the a/c system that was wrapped crappily in ecectrical tape when the a/c was pulled. I think that I will do the installation later this winter when I get an old bug to be transformed into a baja bug to drive while I overhual my z. I have to do all of the bushings and shocks and a new exhaust.
