Belt tensioner
Old 08-07-2007, 01:05 PM
Texizgreat's Avatar
Belt tensioner
I have a loose belt. My question is how to i move the tensioner to tighten. There is a bolt on the top and from what i can see a bolt in the middle of the pully. do I loosen the bolt in the middle of the pully? when i turn the bolt on the top nothing happens except the bolt comes out.
Texizgreat is offline
Old 08-07-2007, 01:36 PM
Loosen the center nut (I believe it's 14mm) and then you can adjust the tension with that diagonal bolt (12mm?).
NismoPick is offline
Old 08-07-2007, 01:54 PM
Texizgreat's Avatar
thank you
will try when i get home today
Weekend project .... BUSHINGS
Old 08-08-2007, 06:08 AM
Texizgreat's Avatar
Ok Got the belt tighter... I could not get the belt as tight as i wanted. The positive thing is that the noise from the belts are almost completely gone.
280z dude
02-05-2015 06:57 PM
kamshaftz
09-23-2013 10:19 AM
Mrmoose
01-29-2011 09:50 PM
KasbeKZ
12-21-2007 05:10 AM
KasbeKZ
18
11-18-2007 04:02 PM
Quick Reply: Belt tensioner
