L26 crank and pistons into an L24 motor.
Old 02-13-2014, 07:26 PM
galann's Avatar
Can I use the crank connecting rods and pistons from an L26 motor in an L24 motor? If so will it improve performance?
galann is offline
Old 02-13-2014, 07:51 PM
The Emblem Thief y0!
WanganDevilZ's Avatar
Why not just swap in an L26 motor? That's basically what you would be doing.
Also, all that work for around 11hp?
Engine: 2,393 cc (146.0 cu in) L24 I-6, cast-iron block, alloy head, two valves per cylinder, seven-bearing crankshaft, single overhead cam, 9.0:1 compression; Maximum recommended engine speed 7000 rpm.
Bore: 83.0 mm (3.27 in)
Stroke: 73.7 mm (2.90 in)
Power: 151 hp (113 kW) at 5600 rpm (SAE gross)
Torque: 146 lbf·ft (198 N·m) at 4400 rpm (SAE gross)
Engine: 2.6 L (160 cu in) L26 I6, cast-iron block, alloy head, two valve per cylinder, seven-bearing crankshaft, single overhead camshaft
Displacement: 156.6 cu in (2,565 cc)
Stroke: 79.0 mm (3.11 in)
Compression Ratio: 8.3:1 (93 oct)
Power: 162 hp (121 kW) at 5,600 rpm
Torque: 157 ft·lbf (213 N·m) at 4,400 rpm
WanganDevilZ is offline
Old 02-13-2014, 08:13 PM
galann's Avatar
The L26 motor has pits on the cylinder walls, and needs to be bored to be repaired. My L24 motor is fine, but needs new rings. So since I have them both apart, and don't want to spend money on boring, I figured, why not ask.
galann is offline
Old 02-18-2014, 06:03 AM
I have a present for you...
theramz's Avatar
The L26 has the same bore as the L24 with the stroke the same as the L28.
As long as you keep the rods and pistons together in the same order. It would be a good idea to use plastigages for assembly even if you have the crank polished or reground. New rings and bearings of course. You should get around +20 torque. The ratings for that 260 are with the crappy E88 head and junk flat top carbs. Back in the day a 240 would out run a 260 any time.
theramz is offline
todd5854
05-06-2014 12:35 PM
bobsmiley1927
07-30-2006 12:30 PM
81s280zx
14
10-07-2005 10:48 AM
dr. buddha
01-08-2004 09:33 AM
z17
08-27-2002 01:02 PM
Quick Reply: L26 crank and pistons into an L24 motor.
