Hi Quality engine and transmission seals and gaskets
I need the following parts for my 240z but with Premium high quality standards:
Urethane Bushing kit
Steering Rack boots
Crankcase gasket or ENgine overhaul gasket kit
Rear Main seal / crankshaft
Front and Rear transmission Seal
Front cover gasket engine
Rear differential cover seal
Rear differential Seal
Should i purchase these seals and bushings in Black Dragon or should i really invest on high end part supplier? if so which one carries all these parts.
Steering Rack boots
Steering Rack boots
Steering Rack boots
However, I have had a good experience with the urethane bushing kit from Energy Suspension. There are lots of vendors selling that particular product.
Just curious, is it a requirement you purchase all those parts from the same place?
I've never purchased anything from Black Dragon so I can't tell you anything about the quality of their offerings.
Just searched in Rock Auto. I have still not found any OEM datsun 240z engine and transmission gaskets or seals. Who is the manufacturer that is now producing Nissan Factory seals?
IF you are looking specifically for Datsun/Nissan OEM parts, the best source for me has been Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com. Remember Nissan stopped building the L24 engine in the early 1980's. True OEM parts may be sparse. If Courtesy Parts cannot find the part, it's likely not available. There are lots of good gasket manufacturers. a vendor like Summit or Jeg's can offer lots of good alternatives to OEM. One piece of advice I came across on this forum concerned head gaskets where OEM Nissan was strongly suggested.
Prothane makes an excellent urethane bushing product. You can buy them directly from Prothane or from several vendors. Make sure you buy kits that come with the installation lubricant included.
blackweb
01-07-2013 06:42 PM
ReVg30De
09-26-2003 05:22 PM
