Fuel help 280zx
Old 02-08-2016, 06:00 AM
npayton86's Avatar
Lightbulb Fuel help 280zx
Hello,
I am a new owner of a 81 280zx NA and i found this site and i had a question that i couldn't find the answer while browsing. i have the L28, with the pall net fuel rail and an after market fuel pump and fuel reg.
Fuel pump is a Wall-bro 255 and the Regulator i believe is a pro fuel but my problem is that when i try to dial my pressure down to the 36-40 range psi i can only get it down to 60psi while running.. i am wondering do i have a vacuum leak because i smoothed out my intake and have the fuel reg. vacuum line going to a tiny hook up on the throttle. do i need to have it attached at the intake some where better.
Im just not sure what direction to go from here and any help would be appreciated. Thank you
npayton86 is offline
Old 02-08-2016, 08:13 AM
Welcome to ZDriver!
Could you post a pic of your fuel pressure regulator?
NismoPick is offline
S130Monica
01-26-2015 08:02 AM
280zinkansas
04-27-2004 10:26 AM
280ZXtreme
04-10-2001 07:00 AM
Quick Reply: Fuel help 280zx
