280Z goes flat at 3000RPM Im stumped Please help!
Old 09-29-2016, 03:54 PM
BillyD Z's Avatar
So we have a 78 280Z. When in neutral she seems to rev up just fine. Small hesitation but things crazy. Once you drive her and get her under load that's where things go south. When she gets up to 2800-3000 RPM she goes flat with no power.
We changed the plugs, wires, cap and router, PCV and fuel filter your regular tune up. Also checked the air flow meter and that was bad so that was replaced. I also checked the fuel pressure and that is spot on as well and stays at proper pressure when revving it up.
Has someone out there experienced this before?
Thank you in advance for your help everyone!
BillyD Z is offline
Old 10-06-2016, 07:39 PM
BattleGround's Avatar
This sounds similar to a problem I had on some 240SX's one ended up being the timing 180 out. the other ended up needing the ECU replaced or the ecu connector cleaned. I can't remember now it was a few years ago.
BattleGround is offline
Old 10-30-2016, 12:32 AM
moparmusclecars's Avatar
BillyD, any luck yet? I have the same issue as you do happening with my 77 280Z.
moparmusclecars is offline
GTR
04-20-2010 11:21 PM
-Z-
01-02-2008 01:36 PM
ever888
08-07-2007 09:46 AM
chef_tickwon
06-06-2003 06:12 PM
ContagiouSzxt
11-14-2002 02:56 PM
Quick Reply: 280Z goes flat at 3000RPM Im stumped Please help!
