brake problems on my 260
Guest
Posts: n/a
I changed the pads on my front discs and discovered when I took the pads out the inside piston on the front-right wheel was not as far pushed in as the others and the pad was not as worn as the other side of the rotor. help me please, thanx.
Rebuild both front calipers. When you remove the piston out of the frozen caliper, use some fine sandpaper (400-600grit) to smooth off any surface rust or corrosion on the piston and the inside of the caliper. That should do it. The rebuild kits are just new rubber seals. A kit should cost $10-15 for both calipers.
jab83
02-28-2014 06:34 PM
