Body work
Old 05-14-2015, 11:49 AM
  #51
I have a present for you...
theramz's Avatar
patch work
Drilled some holes in the inner fender for rosette welds and welded in a backer strip so I can re install the inner portion I cut out. Now I have the shape of the quarter back. This is a lot easier than butt welding.
theramz is offline
Old 05-14-2015, 12:13 PM
  #52
theramz's Avatar
Welded in a hand cut piece for the inner part that I cut out leaving it extra long.
Aligned the patch panel and stitch welded it in. Next I'll patch the space on the inner fender. This way I can put down some healthy welds and grind/ file them smooth and just wipe with some filler.
Attached Thumbnails Body work-wp_001976.jpg   Body work-wp_001977.jpg   Body work-wp_001978.jpg   Body work-wp_001981.jpg   Body work-wp_001984.jpg
Body work-wp_001987.jpg   Body work-wp_002000.jpg   Body work-wp_002001.jpg   Body work-wp_002003.jpg   Body work-wp_002004.jpg
theramz is offline
Old 05-14-2015, 05:59 PM
  #53
beg3yrs's Avatar
Glad you got some more time for the project. That's a lot of work Ramz. Love to see the progress photos, thanks.
beg3yrs is offline
Old 05-17-2015, 06:56 PM
  #54
theramz's Avatar
Fitted the inner lower piece. Welded it in and then bent it out and down to meet the patch panel. Drilled holes for rossette type welds. So much for Sunday. Next I'll make patches for the remainder of the inner portion. Next week is a four day holiday. Also half price day ant the local pick n pull!
Attached Thumbnails Body work-wp_002015.jpg   Body work-wp_002016.jpg   Body work-wp_002017.jpg
theramz is offline
Old 06-11-2015, 07:06 AM
  #55
Kerrys914's Avatar
Any updates? I am doing some of these repairs to my 280z now.. This is nice/fun to follow you.
Kerrys914 is offline
Old 06-11-2015, 07:08 AM
  #56
Kerrys914's Avatar
Where do you use a overlapping stitch weld and where do you drill hole for rotisserie type welds (not a complete weld) ?
Old 06-11-2015, 09:56 AM
  #57
theramz's Avatar
I just decide by what happens next after or during the weld. On old thin metal a butt weld will just make more holes than I can chase. I also don't want to warp the metal. The plug or rosette type welds can mimic the oem spot welds. and avoid edge welds where the panels meet like at the rockers and fender. I like using the backer so It's easier to get everything aligned such as the inner fender.
You should start a thread showing your work so others can learn.
I might get a day this weekend.
theramz is offline
Old 06-12-2015, 09:18 AM
  #58
Kerrys914's Avatar
Have you used Eastwoods internal Frame Primer? It has a hose to spray primer into the frame rail to coat the inside and reduce the chances of rust forming and spreading.
I am dropping my 1st welds this weekend.
Did you shave the rear bumper?
Old 06-12-2015, 10:00 AM
  #59
theramz's Avatar
I'll have to check that out. I am leaving an opening in the inner fender to spray in rust proofing into the rocker before closing it up. Then spray fom the inside of the hatch area.
No, I'm not going to shave the rear.
theramz is offline
Old 06-15-2015, 11:53 AM
  #60
theramz's Avatar
Got some time to fab up an inner fender piece. I just folded over a piece and ran it through my shrinker die set to get the same curve as the outer piece. Tuck it in place spot welded it in. I'll cut the rest of the little pieces and weld it all up. With all the work I had to do to the patch panel I bought I could have made the whole thing.
Attached Thumbnails Body work-inner-fender-piece.jpg   Body work-inner-fender-piece-2.jpg   Body work-inner-fender-piece-3.jpg
theramz is offline
Old 07-28-2015, 08:51 AM
  #61
Kerrys914's Avatar
How has the Z project been going?
Old 07-28-2015, 09:37 AM
  #62
theramz's Avatar
Was able to work on it this weekend and got the inner fender welded back in. Ran out of gas on my welder so maybe on it again Friday. Will post pics of progress. Slow goin like old people ***k, oh wait, I am old people.
theramz is offline
Old 07-30-2015, 09:32 AM
  #63
theramz's Avatar
Got some time in last night and made up some more pieces for the inner fender. Ground and filed some of the welds down. Maybe tomorrow I can fill the gaps with more weld to end up with mostly metal to finish.
Attached Thumbnails Body work-fender-weld-up-1.jpg   Body work-fender-weld-up-2.jpg
theramz is offline
Old 08-02-2015, 08:57 PM
  #64
theramz's Avatar
Made the last patch to complete the inner fender. A inner corner to weld to with my shrinker die. Made a pattern for the patch and shaped the edge radius for a stronger piece. Stitched it in and now for a lot of filling with wire feed and grind it smooth. Then contour the outer welds with a Vixen or body file. Ran out of wire and smoked the grinder.
It is difficult to see inside the fender well before I stike the arc so I came up with this idea to put LED lights in the helmet. Now I can see to position the torch exactly.
Attached Thumbnails Body work-last-patch-cut-out.jpg   Body work-last-patch-shaped.jpg   Body work-last-patch-stitched-.jpg   Body work-lat-patch.jpg   Body work-led-helmet.jpg
theramz is offline
Old 08-03-2015, 07:58 AM
  #65
beg3yrs's Avatar
That's some real skilled work Tom. Too bad about the grinder though. I just hate it when a tool dies in the middle of a task. I'm pretty sure I've worn out at least one set of tires going to the hardware/auto parts/tool store over the last couple of years.
Pretty slick idea with the LEDs on the helmet too. File a patent if you haven't seen that one before!
beg3yrs is offline
Old 08-03-2015, 09:35 AM
  #66
theramz's Avatar
It went up in smoke while I had my head inside the fender well in a shower of sparks, thought I was on fire or the car. Didn't know I could move that fast lol.
theramz is offline
Old 08-31-2015, 03:51 PM
  #67
theramz's Avatar
Found a few hours and smoothed out what I had so far. I ground all the boogery welds down smooth to where I could use the vixen files on it. Don't want to grind the original metal any thinner than it already is. Inner fender is good enough to coat.
theramz is offline
Old 09-01-2015, 09:01 AM
  #68
beg3yrs's Avatar
Keeps on looking better every time you post. I hope you get more free time soon.
beg3yrs is offline
Old 10-21-2015, 09:07 AM
  #69
theramz's Avatar
back to work
Just getting over triple surgery on my shoulder and chomping at the bit. Since all I could do is look at it I decided to fill in the rear valance and bumper indents on the sides.
To make the patches I taped off the area and drew a line around the edge at the radius. I wanted to make the patches as even with the surface as possible. This way to minimize the thickness of the filler. First I'll weld the top edge even with the body panel and fill the gap with weld. Then weld the bottom edge flush.. This is much better than having the edge too high and grinding the patch too thin.
Attached Thumbnails Body work-valance-patch-1.jpg   Body work-valance-patch-2.jpg   Body work-valance-patch-3.jpg   Body work-bumper-fill-2.jpg   Body work-bumper-fill-3.jpg
theramz is offline
Old 10-21-2015, 10:33 PM
  #70
beg3yrs's Avatar
That's really nice work Tom. Those patches fit like a glove.
Keep on recuperating and you'll be back at it in no time...
beg3yrs is offline
Old 10-22-2015, 06:07 AM
  #71
theramz's Avatar
Thanks Scott.
I'm going to use these 944 Porsche bumpers. They line up better than this picture.
theramz is offline
Old 10-29-2015, 08:58 PM
  #72
theramz's Avatar
Made patch panels for the bumper indents. I cut them a little smaller than the space. I made long welds spaced 2" apart. As I went along I was able to push in or reach behind with a hacksaw blade and pry out to keep the panel as flush as possible. That way I can minimize the amount of filler.
theramz is offline
Old 11-09-2015, 07:35 AM
  #73
theramz's Avatar
Made these patches and used my stud welder to make little handles to hold them while I spotted them in. Filled the antennae hole bumper holes and side mirror. After rough grinding I can see I need a little more welding to fill the larger pock holes.
Attached Thumbnails Body work-valance-patch-4.jpg   Body work-small-patches.jpg   Body work-antennae-patch-1.jpg   Body work-patch-welded-1.jpg   Body work-patch-welded3.jpg
theramz is offline
Old 12-30-2015, 11:30 AM
  #74
cyclopsblown34's Avatar
Originally Posted by theramz
Yes, and that presents a whole set of problems. I cleaned everything, blew out all the pockets that might have dust, wet the floor down. I had a respirator on but the 2 little tiny nats did not. When they died on the paint it left a little tiny image of them with metallic highlights. Barely noticeable but there. I will drape the inside with plastic next time or rent a spray booth at the college.
Did the gnats do the death march through the clear?
cyclopsblown34 is offline
Old 12-30-2015, 12:08 PM
  #75
Great work! Thank you for sharing!
Quick Reply: Body work
